Details here: TDR Privileges
You may find the MAP plug on your new box doesn't match the receptacle for the stock MAP... ... ... . if so, take/send the box back and tell them you need the correct plug. Just went thru this last week with a friend's early 2000 Ram. Just FYI..... other than that, yeehawwww.... ...
just installed boost elbow, and module. yeeehaw. can see 24 pound of boost only at max. if i back out adjuster screw on elbow, i loose boost. Its nice to see a diesel burn rubber!!!!!!!!!!!!!!!
