Details here: TDR Privileges
Does anyone make a boost fooler only for 600s up. If you add injectors and bigger turbo(s) you will get "over boost" codes without something to do boost fooling. Does anyone make just a box/plug adapter to do boost fooling only??
I thought that the EZ's for the 600's dont boost fool?
If you were to boost fool the 600's the WG actuator wouldnt get a signal and open the WG up. Thats why alot of people wasted turbos with the TST on the 600's because it did boost fool and didnt open up the WG. The EZ just uses the MAP sensor for 5v power and engine load to raise rail pressure on the 600's.
If not I can flip my plugs tomarrow and see if it does via the TST digital boost gauge.
