Boost fooler stacked with edge
Need help with recurring P0148 code and other issues
P0148 Code
My edge chip recently had some issues and i had to remove it. I cant afford to get the new edge CTS just yet, so i was looking into getting a boost fooler so that way i could take advantage of my turbo and injectors. My question is if i install a boost fooler can i leave it inline with the edge, or would i be wasting my money and should just wait till i can afford the edge again?
I can't answer your question on the boost fooler but my edge on my 03 also as recently started acting up. I was wondering what yours had started doing wrong.
Mine was surging and finally triped a code with the map sensor. After trying a new map sensor the problem was still there. When I would disconnect the power from the edge the problem was still there also. Only when I completely removed the edge did the problem go away. On a side note the timing rattle is alot quieter without the edge.
They can be inline but the Edge boost fools as well. I dont think there will be any benefit gained by leaving it in place after re-installing the edge; just another fail point.
That is one problem with "chips" they themselves or the connections go bad. This happens quite often. That is one reason I went the Smarty Jr route.
After doing an ohm test on the injectors and the cross over wires, i unhooked the wires from the edge to the injector wires and that ended up taking care of it. I would really like to go to a smarty but i like how the edge can defuel and i wont have to buy the extra gauges.
That is my issue too, I like having the defueling option as I let several others drive the truck when we are rodeoing pretty hard. I know i will watch the gauges and back out of it if needed, but hard to feel safe that someone else will. I quess I will send the edge in and have it repaired.
Thanks for your info.
