Boost fooler
Do we even need a functioning lift pump?
Ordering gauges...
With an automatic transmission, K&N OEM style and only a VA as an upgrade, will a boost elbow (as in pratical solutions) do me any good? Will I see ANY power increase at all? How about egt's? Thanks... Joe
Pratical Solutions told me you will not see anymore HP but it will lower your egt's by about 200 degrees, because it gives you more boost pressure.
Rod
I disconnected the wastegate line and put a plug in the turbo. I gained about 7 lbs boost. If I run it that way am I looking for trouble soon? I was unable to get any information from autowurksdiesel.com about the wastegate bypass kit. What does it do?
