Engine/Transmission (1998.5 - 2002) Boost Fooler
Engine/Transmission (1998.5 - 2002) 2001 Heavily Modified Boost Problem
Engine/Transmission (1994 - 1998) GSK help
The turbo on this truck has the waist gate suppy line steal, Im wandering about the hookup and if anyone has a pic of the setup. also at what psi does the ecm flag over boost? TIA Harv
If the actuator line is the hard line (steel tubing) then you use a J-hook. Do a search on J-hook and you will find everything you need. Do not go over about 21 PSI without a boost module.
Most boost fooler kits have a new elbow or a fitting stopper with their kits. The one I used came with picture diagrahms. If you mess with the wastegate you must have a fooler. Good luck
