If you can drill and tap a 1/8 NPT hole, A good and easy place to put it is on the aluminum intake just above the alum. lip stop above the rubber /clamp intake conector. You will see a vertical casting seem there. Drill just behind the seem and just above the lip stop. The Aluminum is 1/4" thick there. Just loosen the rubber connector, slide it down completely on the black intake pipe, cover it with a baggy (so no chips fall in there) and stuf a clean rag up into the intake horn passed where you will drill. Drill, tap and reassemble! Very, very easy to get at.
