I Installed DiPricol gauges, love them but I have this high pitched whirling sound at 16 PSI and up. when it first appeared it was at 10 PSI, I then sealed the threads on the 1/8 NPT base in the aluminum air intake. Then the sound appeared at 16 PSI.
I assume this is escaping air around the capillary tubing fitting , they seem tight enough if I tighten any tighter I feel like I will distort the brass cap. Any of you guys have a solution or idea?
Thanks JJ
Thanks JJ
