Boost Gauge Questions
Low power cut off devices, etc > good find
Western Diesel air filter
I searched for the the answers to all of my questions about the installation of my guages but I still have two unanswered questions.
1. Is a 30psi boost gauge "big" enough as long as I stay with the HX35?
2. There was a lot of feedback about which boost line to use, nylon, copper, stainless. I assume the stainless is best, but at what cost? Is there any drawback to the nylon other than kinkability (if that's even a word)? I like the idea of pushing the nylon through copper or flex-pvc.
TIA, Ryan
I use nylon line all of the time in CNC machine tools. Some of the places I put this stuff are incredibly bad environments. The only thing you have to watch out for is kinks and heat. This should not be a problem. There are different grades, with the best I have used to date being the Parker 250 PSI, so don't get the garbage at the local hardware store. A hydraulics supply house will have it.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S
30lb gauge is probably good for the HX35.
I use nylon all the time, and had more trouble with cooper kinking than the nylon in the past.
Owner: Stabco Repower-stabco@bbc.net The turbo housing guys. '89, CC, SB, 5sp, 3. 54, 16cm2 housing, intercooled, maxed fuel, KN, Banks exh w/muffler, Horton fan clutch, Autometer liquid filled gauges, Accessory tach option, 100% Dyna-Mat, Borgeson steering shaft, Firestone air bags, Chrysler V-twin air comp, 2. 5" lift, Rancho Shocks, Alcoa LTS wheels (recalled), BFG 255/85/R16 MTs (33. 3")
<font color=blue>I would get at least a 35psi gauge if your gonna do "mild" BomB'ing or even just stay stock. The 35psi would give you a lil more room for future mods then a 30psi would. If you intend to do any major BOMBing then I would suggest a 50lb gauge.
TIA, Ryan
I've seen over 35 pounds on my HX35, but I have a 16 cm housing.
Tackett
'97 4x4, 370s, timed pump, AFC spring kit, BD gov spring kit, #5 TST plate, BIG smile.
I've pegged a 40# gauge with my 3500 with a good load,get at least a 40. I use the nylon line but feed it thru 1/4" poly irrigation tubing before installing,keeps it from kinking and protects it from sharp edges.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
I thought the 30 was too small, thanks for clearing that up.
My dilema is I really am set on the VDO Vision gauges and they only make a 30. I remember reading something that I could use an engine oil pressure guage. The smallest is 80 so it would not be too accurate in determining lower boost numbers.
Any suggestions?
Thanks again, Ryan
