When i start to make approx 20 psi of boost and anything over, the needle on my autometer boost gauge will shake rapidly fluctuating maybe 3psi. I have it Tapped into the aluminum intake and teflon taped. It did it with stock turbo and now does it with an hx40, I've tried two boost gauges and new nylon line with same result. Also egt's seem to run pretty high for my taste as far as cruising goes. used to run 750-800 at 55-60mph, now with the hx40 it will run anywhere from 800-900 cruising the same speeds mentioned. Any idea's what would cause the boost gauge to fluctuate that much on a stock engine with just some 80hp injectors? no boost fooler or anything, but don't think thats the problem with the fluctuating gauge. do i have a boost leak? any opinions appreciated.
2000 auto 80hp injectors hx40.
