Reply
I'll try and answer some of the questions posed.
I don't get it. I was always told the stock turbo is great for low end and midrange. For top end or climbing hills, the bigger turbine housing will move more air to help the EGT problem. I know that the bigger turbo will spool slower at bottom end and that doesn't help clean up smoke down there. The stock turbo just runs out of steam. I had the same situation with EGTs with this hill, with my stock turbo. The difference I noticed in the upgraded turbo is the EGTs just climb slower with the bigger turbo.
I don't have the pedal smashed to the floor at all. I'm EGT limited.
The hill I'm using is on the East 138 by Mountain High coming from the 15 (West bound).
I can get 30 PSI boost if I get on it at a low RPM situation without the trailer, but that only lasts a few seconds, then goes down to 15 or so.
I have checked for air leaks and everthing looks good. Took some hoses off to check for cracks, tightened clamps, shade tree pressure test, etc.
The trailer I tow is a toy hauler and it's a heavy beast. Probably around 14k to 15k loaded.
My RPM is around 2500 to 2700 and that sounds more in the upper RPM range for the motor than mid range and would expect more boost.
With the box off and just the EDMs working, it still gets hot fast. RV275s instead??? (probably just a weight issue)
Thanks
