Steve,
Philip is right on about the 1/8" pipe plug in the manifold. I have an early 91 as well, and what I did was drill a 3/4" hole in the throttle linkage bracket. Be careful if you leave the bracket on the motor, as there is really only one good location to drill. There is a decent gap around the injections lines towards the center of this bracket. Take a trouble light and you'll be able to see the pipe plug. It should be sticking out about an 1", you'll know it what you see it. Then install the boost fitting and run the boost tube through the hole you drilled. By the way, this is best accomplished if you've take the linkage bracket loose. Hope I didn't make that sound complicated.
Dustin
