BOOST INSTALL
first gen pump lifespan?
PW Injectors, lost power?
I got my gauges today from TST
They include the instruction with it but
i'm confuse. The 7/16 plug or cup that is
below the pipe from the turbo , there is where the brass fitting and 1/8 tubing fitting goes? I order PW injectors ,the pump
still stock. I wiil need to ajust the smoke when i set the injectors? Any help appreciated
93 dodge 2 w auto 5. 9 str. pipe K&N filter.
Julio,
The plug is just below the inlet air heaters wher the inlet pipe from the turbo comes in. Sounds like you are looking at the right one.
As far as adjusting for too much smoke, that depends on how much you can live with. Mine is definetly smoking more but only when I put my foot in it. I'm not worried about it yet cause I still need to adjust the power level of the pump.
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
