Been having low boost problems. After installing Piers HX35 I was expecting to see more boost than 25lbs,so did the obvious checking all the clamps which seemed ok,couldnt find anything else amiss,still only 25lbs. Stopped by Eimler Diesel here in Sac & was telling Ken about the lack of boost & he agree,d I should be getting a lot more. We pop the the hood & he immediately points that the bottom hose on the intercooler has been rubbing on the fender lip & it is cut as it is only a fraction away & he said he see,s these balloon up when they are on the dyno under a load.
So go down the dealer to get a new one thinking $20 to $30. The parts guy told me to sit down as they want $150 for one. I politely declined & walked outI know it,s a specialized hose ,a 6"hump hose that goes from 2. 5" to 3. 5" ,$150give me a fricking break . Called round the dismantle yards & found one for $75. Whilst installing it I bent the fender lip down to improve clearance & then attached an old fire hose to shield the hose from the fender. After all that I still only gaIned 4lbs which wasnt the dramatic improvement i expected after spending $75. Any other suggestions to increase boost would be appreciated .
Thought it might be prudent for you guys to check that hose & at least bend that fender lip down to avoid a $150 bill.
Ian
Ian
