When is a leak bad enough to warrant fixing? All the hoses have small seepage with 10 psi. It takes a while for the foam to develop so they're not gross leaks. Even the intake manifold to the block has seepage as well as the sensor in the manifold. Should they be repaired or wait until / if they get worse?
Also, should the turbo blades be cleaned or left alone? Would spraying them with carb cleaner hurt anything? Turbo at around 70K (it was not cleaned)
Turbo at 130K
Turbo at 130K
