OK, I've got a weird one that I do not see anywhere on the forums. It's not a dead petal. Here's the scenario.
Cruising at 70-75 on basically level, no hills, interstate with normal boost displayed on manual gauge. Then, when a hill that requires more power to maintain speed is encountered the throttle responds but the boost does not increase. I can hear the throttle change but the engine can't develop more power. This will happen whether I am using cruise control or not.
If I release the throttle and reapply the engine goes to no power and then returns to the maximum boost it had before..but...if I release throttle, disengage clutch and allow the engine to come to idle, then reengage, the boost comes back to life and everything is normal..... for a while.
I changed the MAP (Boost) sensor and the only change that it made was that releasing the throttle and allowing the boost to go to zero now resets. I don't need to disengage the clutch. I suspected the MAP as I have not seen this problem at 55-60 and concluded that the boost was being reported wrong to the PCM.
I changed the IAT and it made no difference. (the original was oil caked but tests ok)
Here's the setup.
-I have a smarty but changing programming makes no change in the problem.
-Waste gate is free and functional. (When running right it runs from 0 to over 35psi)
-APPS (TPS) is the genos replacement and is fine (and since this happens using only the cruise control the APPS is not in the circuit when the problem occurs.
-2002 5.9HO with 4" turbo elbow and exhaust
-pacbrake exhaust brake - that is full open and I have not used since trying to fix this.
-5volts test good in multiple locations
Thought about grounds this morning and am going to check the ground on the PCM but I am beginning to suspect that it may be the source of the problem.
Anyone have any thoughts or ideas on this? I'm running on empty for things to test.
Thanks
Here's the setup.
Thanks
