Running on 3/3; my max boost is 25lbs; even when towing. It'll momentarily spike to around 30 but immediately comes back down. Just for a test I turned it to 6/4 and I see the exact same behavior.
Towing on 3/3 I see the same numbers. I also noticed that my vacuum gauge dropped to "75% restriction". Perhaps the engine's running out of air???? With an AFE pro guard and intake? Or maybe I can't get the exhaust gases out quick enough... . but I wouldn't expect the vacuum gauge to drop if the exhaust side was the issue. ATS manifold going on this weekend; stacks too if the parts get here; fuel pressure sensor also on order.
I chatted with Mark Chapple and we suspect running out of fuel mighty quick; could be weak pump and will only support that 24lb output.
Other experiences re: boost levels with TST at 3/3 or thereabouts?
Curious about this boost thing; but the TST has been great!
