Ok I posted in the 911 section sun. my edge comp drag was stole on sat night
had engine light come on,checked the codes it was an overboost code. it was suggested that I disconnect the map sensor from the box wire harness. I did, however I do not have the stock cover to put back on. is that just a dust cover? the motor should be stock now right? the thing has little power and will not make more than 15 psi boost. I wonder if the converter may be the prob it is a low stall and was installed after the box so I don't know how the truck performes with out it. any help thanks.
