Engine/Transmission (1994 - 1998) boost preasure
Engine/Transmission (1998.5 - 2002) Broken Pump Wire
Engine/Transmission (1994 - 1998) flat spot on the top end
I was curious if there was a way to obtain more low end boost preasure with my stock turbo. I installed larger exhaust(no cat), larger injecters and slid the plate up a little. Some more air would be nice. The wast gate is operating normally and dumping around 23lbs. I know how to adjust that to get more high end boost, so is there a way to get more low end boost? thanks
More low end
I would suggest that you slide your afc housing full forward and adjust the starwheel full forward towards the front of the truck. Sooner the fuel comes on the faster the boost will build. Oo.
