So I just installed an Isspro 60 lb boost gauge, and am a little disturbed by what I'm seeing. I spent time replumbing the gauge, and putting new compression fittings, teflon tape, etc trying to ensure it wasn't my install that's the problem. I also tightened down all the intake hoses, and checked for boost leaks. I can't find anythign wrong with any of that. Here's the issue: I only see MAX quick spikes of 30 lbs before the waste gate opens, and then pressure settles back around 26 or so. It will typically not exceed 26-28 lbs under WOT, then the waste gate opens and settle down at 24-26 lbs. Would the waste gate be opening at that low of pressures? The reason for that question, is: Is my gauge reading low, and the map is reading 32ish and opening the waste gate like it's supposed to? Is there something wrong with my truck? If it only gets to 26 or 28 lbs under WOT, would it open the waste gate? I've also heard that boost foolers are supposed to hold the waste gate shut, and I should be seeing close to 40 lbs using one. I borrowed a boost fooler, and it will only get to 34 lbs with that on. I tried it just to test this problem - my truck is TOTALLY stock as far as the engine controls and such. I removed the intake baffles, and that's it - other than analog Isspro gauges and 285's. The truck is a 2005 with 56K on the clock.
Thanks for the input!
