boost pressure vs. volume questions
drilling injectors
More future Mercedes diesel rumblings?
AMink
So I've read here that more volume will result in lower egt's, but that more boost doesn't necessarily mean more volume. I think that's what I read, at least. Wouldn't volume be equal at any given boost pressure on different turbos? I mean, if a stock turbo is making 18 psi, would a 40 or bigger making 18 psi be moving the same amount of air? If it moved more, wouldn't the pressure go up? Am I making sense? :-laf :confused:
The HX-35 has a smaller turbine outlet than the 40. The 40 is 4" vs. 3 or 3 1/2". Meaning less restriction= less boost required to move the same amount of air.
So do you need a higher boost to "push" the air into the combustion chamber? I always assumed (and we know about that!) that you needed the pressure, or boost, to shove the air into the engine. I understand the higher volume, lower pressure thing though. Thanks!
Since an HX-35 is working outside of it's effeciency range making say 42 psi the air that it compresses is hotter than the air of a larger turbo like an HX-40 making 42 psi, therefore the HX-35 air is less dense and has less air mass for cooling and combustion purposes. Take a look at these numbers for air temperature versus pressure:
Other factors equal, the volume of the air in the tire will change by 1/273 for each degree (Celsius or Kelvin) change in temperature. A span of 0 degrees F (-17. 8 C or 255 K) to 100 F (37. 8 C or 311 K) represents an approximately 55 degree C or K difference. Thus, the volume of a tire (considered 1 unit) would expand to about 1. 2 units. Likewise, the pressure inside would rise by a factor of about 1. 2 as well.
For example: The pressure inside a tire containing air at 80 lb/in^2 (5. 44 atm) at 0 F would rise to about 96 lb/in^2 (6. 5 atm) at 100 F.
So if the air out of your intercooler was 1 cubic foot at 0 degrees with one turbo and 1 cubic foot at 100 degrees with the other you can see the differences in volume after reaching combustion temperature right?
Quote from a HotRod Magazine: Every 100 degrees F reduction in air temperature increases air density 12-13 percent, greatly increasing engine power output.
If you do a search on Google for Air Density Turbo Efficiency you will find some pretty good reading.
