2nd Gen Non-Engine/Transmission boost pressure
Guy's, where do you get your most accurate boost reading from? #1 drilling the air horn #2 use Piers boost fitting #3 pulling the plug on the block I think this plug is a port where DC mechanics tap in, is one any better than another Thank's Don
I get mine off the block on my '02... replacement plug w/fitting for air tube near fuel filter. Seems to work OK.
I would think it would be accurate on the horn too. I just prefrerred to not drill/tap it.
Wiredawg
Well, let's make it one of each. I used the boost fitting from Piers, works fine. Nothing to compare it to for accuracy, but no troubles either.
I used the 3/4" plug by the fuel filter. Cost me $2 for the reducer at Lowe's. It took me all of about 10 minutes to put the 1/2" socket extension into the hole and back it out. :cool:
