Boost Pressure
Lift pump question???
I have just recently installed my new AutoMeter Ultra-Lite guages (EGT and Boost) in preparation for BOMBING. :D :D I love the guages by the way. My engine is still bone stock. Truck is a 97 5-Spd dually. The boost levels have been 21psi max. I wanted to see how high it would go just as an experiment by un-hooking the waste-gate line from the back of the fuel pump. I have heard that this will let the boost climb up to pretty high levels. When I un-hooked the line however, the boost remained at 21psi. Did I just receive bad information regarding the function of this? How exactly does the waste gate work?
The wastegate doesn't do anything until boost reaches the level at which the wastegate opens. I don't know what this level is, I think it is around 35 to 40 pounds(I'm probably wrong, just a guess). Unless you are making enough boost to open the wastegate unplugging it will make no difference.
Sounds like to me that your truck being unbombed only makes 21 PSI cause the wastegate is spose to open when the pressure gets to a certain level and thusly keep it at that pressure... . or the other possibility is that your wastegate is stuck partly open and lets your turbo only make 21 PSI, what are your EGT's? a stuck wastegate would seem to me to make EGT's higher (?) ... . so push your fuel plate forward and see what happens:D ... Jim
PS on a stock truck I think its spose to open around 24 PSI ( I could be wrong)
My EGT's are in line with where they should be I think. Pulling hard up hills the most I've ever seen is about 1100 deg. I don't think that the wastegate is stuck. I un-hooked the arm from the pod that controls the waste gate opening and the waste-gate flap seemed to move very freely. Drove the truck down the road with the arm off and what a difference. No boost would build and all power was gone. :eek: Can't have that.
