Engine/Transmission (1998.5 - 2002) Boost Q
Engine/Transmission (1994 - 1998) 4" exhuast question& heat blanket
Engine/Transmission (1998.5 - 2002) Re cheap high idle switch
How much boost does the truck come with from the factory stock? The only reason i ask is because i got some gauges installed down at schides last weekend... go time BTW... anyways All I get is 15-18psi which isn't bad, but isn't that good :rolleyes: lol But i thought i would have more then that, but all i have is a BD Plug N Power, which is just fuel i know, and 4 inch straight pipe... mild by some standards but i thought i would get more then that. I just wanna know if that close to what i would be getting or do i have to go check my hose clamps? Thanks for any info... :)
18 to 20 is about right for stock. I get 25 to 28 with my BD box and about 40 with My Blue box on 50%.
I thing your readings a bit low. Check for leaks or intake restriction.
Hope this helps.
John
Interesting one says ok, other says low lol now i have to wait till the truck getshome to look, and if anyone else has any idea, please chime in :)
Does that BD box you have connect to the map sensor at all with a boost module? If it does... ... . have you changed the elbow in the turbo correct? If you have done all that then yes your boost is low.
If you haven't changed the elbow in the turbo (don't do it if you have no boost module)... ... . then your boost is acceptable.
Thats no prob on my part lol i just have to get the other half "my dad" to accept that idea, he just keeps sayin "clutch" when i mention more power lol :rolleyes: :D
