I have read some previous posts that some members have gotten erroneous boost readings when using the pressure port located behind the fuel filter. Since this was the easiest route to go and right next to the factory MAP sensor, I used this as my boost pressure source. The max boost according to my Isspro gauge was about 17# STOCK - I understand I should be getting around 20# STOCK. All hoses are properly seated & tight, boost line is not piched or crimped, wastegate lines seem intact, and I can't find any leaks at the fittings. Thinking about just tapping the intake inlet pipe and getting my boost readings from there as this should be the most accurate anyway. Does anyone have any thoughts or ideas on this subject?
Will - -- email address removed -- - 98. 5 3500, 24v, auto, 4. 10, fold-away gooseneck hitch, Poweredge EZ w/ boost elbow, K&N Filter, Isspro 50# Boost, EGT, transmission Temp gauges mounted on A-pillar, & more to come!
38ft United Expressline X-Treme Race Car Hauler weighing in @ 12000# loaded
Other Bad Habit:
'87 Pro-Street Buick Grand National, 272cid Stage II Buick V-6, SINGLE turbo, 1400hp, 1200ft/lbs @ 24# boost
Best 60ft: 1. 11
Best 1/8 mile: 4. 99 @ 142mph
Best 1/4 mile: 7. 70 @ 179mph
And Lookin' For More!!!
So I'm A Turbo Man!
Boost On!
Other Bad Habit:
Best 60ft: 1. 11
So I'm A Turbo Man!
Boost On!
