Today, I drove the truck and my boost was over 50!!! Smarty is set about as low as possible and so boost only should max out around 30-35. Today, I noticed truck is much more sprightly, so I looked at EGT gauge and only read 750 while zipping along. Then, I looked at boost and was getting 55 ish!
Keep in mind I don't have head studs, too.
I assume my waste gate is sticking or waste gate actuator isn't working. If these are working correctly, I should be able to unhook the hose from the ATS Aurora 4000 that goes to the stock turbo waste gate actuator, apply 30 psi air pressure and see it move back/forth. If it doesn't, that should point me in the right direction? I'm asking, since the tech guy at ATS was no help. He told me to "wait and see if it gets better. ". Yeah, OK...
