2001 and 2002 have solid metal boost elbows to waste gate, you can smash them with pliers, or you can get a j-hook, which slows them down. The elbows that come with most performance add ons tells you they cant be used on late 2000 and up. And with no performance add ons you should have low egt. I have edge ez module, and on lvl 3 i have around 700-800 degrees driving flat unloaded with 6-7 psi boost. WOT 1100 and solid instant 21 psi boost, same when towing, except for higher egt with my 9k 5er. Check boost line, and exhaust probe as the others told you, you will figure it out.
