Borgeson box with BD steering stablizer
2wd ball joints
differential additive
Does anyone out there know from experince if the Borgeson box will work with the BD steering stablizer without modifications? I have the box on order and the stablizer on hold to pick up with the box.
I installed it last week, and yes, I had to bend the plate down to get it closer to being square wit the steering box shaft since it was so far out that it was also tight to one side of the hole. Then I had to drill a new hole for the bearing to bolt on about a 1/2" from one of the existing ones in order to get the bearing bolted on. The results are awsome, it is better than it ever was even when it was new. I can hold the whell soild and no have to do any corrections on the raod at all. I move the whell 1/4" and the wheels move also. ;)
