Borgeson shaft
Banks "Bomb"
Front springs
Did a TDR search for any comments on the Borgeson steering shaft. Could not pull up much. I see several members added them in their sig. Looking for comments on how well they work an hold up. Thanks in advance, Mike
92 Std cab. LE. Brand New 215 HP reman 12 valve P7100 Pump Cummins. 45 miles todate. 5-speed, 3. 54, 105 gal Aux tank in bed. Banks Power pack. 12cm Hot end housing 4" exh. w/wastegate. Pyro & boost guage, oil temp guage. E-brake. Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html
Probably the best money you can spend,
it should be factory equiptment
RD
93 W 250 Spec and pics at site below. <A HREF="http://rducsh.homestead.com/truck.html" TARGET=_blank>
http://rducsh. homestead.com/truck.html </A>
<A HREF="http://albums.photopoint.com/j/AlbumList?u=279120&Auth=false" TARGET=_blank>
http://albums.photopoint.com/j/AlbumList?u=279120&Auth=false</A>
Rick, Thanks for the reply. Thats what I really wanted to hear. I ordered one just before I posted. Will be here Friday. Price not too bad either. Thanks again, Mike
Replaced mine after the steering box started leaking around the seal. Everyone that I talked to including one of the local DC dealers said that the problem was not the steering box but rather the crappy box joint on the original shaft. Went to a local steering box company and had them install a new steering box along with borgerson shaft. A much better design than the old one. I then started looking at a lot of the first generation trucks and noticed that about 95% of the steering boxes were leaking. The borgerson was installed over two years ago and so far no problems with leaks.
92LE,Cummins,Tach,4x4,5spd,3. 54,Borgeson steering shaft,
I just replaced my steering box this winter and it is leaking already from the end of the box by that factory joint. I'm probably going to put in that shaft when I replace it. I had replace the joint last summer with one from the dealer, just before joining TDR. Looks like I wasted good money.
Matt
90 W250, 5-speed, 3. 54 gears, 16 cm2 housing, tach, pyro, and boost gauges, K&N air filter.
I totally agree with Rick, and you did the right thing by ordering it. My truck had so much play in the steering that you had to constantly correct your path. 10 minutes later, I had tight steering, when I turned the steering wheel, the wheels moved. You will be very happy with the results! Some of the best, functional, money ever spent.
No problems with a leaky box here!
'93 D350 2wd Club Cab 5-speed,136,000 miles,K&N,Amsoil throughout,Borgeson Steering Shaft,Isspro gauges(Tach,EGT,Boost,Engine Oil Temp. ),16cm Turbo Housing, "My Dream Exhaust"(5" Chrome Stack)
I fitted one to a neighbours W250 a few months ago, he is very happy with it, cost over $C300.
My steering box was leaking, had seal changed, added grease nipple to the original coupling, so far so good, grease it each time I grease the steering.
Ian.
'93 D250 ext. cab. Upgraded injectors, 3. 5" exhaust, K & N filter, Xmsn oil cooler and fan, 4 gauge mount, mirror tubes reversed, RACOR fuel filter, larger transmission oil pan.
I have 100K on my stock equipment and pulled my 4 horse trailer (loaded) with my 9. 5 cabover and wandered all over the road. I'm replacing the shaft and old school's recommended upper king pin bushing kit. It's a lot of work to drive the way it is.
'93 W250 extended; Turned up pump; 275 HP injectors; K&N; etc; etc
