Borgeson steering gears
Toe in/out setting for 06 2wd, quad, with short bed.
Changing center bearing
Had stock steering gear start leaking badly at 47000 miles in my 2006 1 ton dually 4x4.
Replaced it with a BORGESON and 6870 miles later it started leaking from bottom seal. Had to have it pulled and returned to BORGESON and I am waiting to here from them about the repair which should be covered by warranty. It will still cost me $200. 00 for the removal and install of the repaired unit.
HAS ANYONE HAD A SIMILAR EXPERIENCE with the BORGESON???:
T Wilson:
Thanks for the reply. I only bought the Borgeson because I had heard nothing but good about them. AND GENO's Garage sells them. Geno's in my past experience carries good stuff you can count on to work properly.
