I ordered borgeson steering shaft today and was told that it has a set screw instead of a pin to hold it on steering box. Does this set screw always line up with hole that pin comes out of or do you have to grind flat spot on splines sometimes? Also, is the pin in the original shaft supposed to be made of plastic? Mine was.
