Borgeson Universal Company Celebrates Its 100th Anniversary
Anderon weight dist hitch?
Show off your RV here!!
Borgeson Universal Company is proud to announce they are entering their 100th year of quality manufacturing and exceptional service.
Borgeson began manufacturing universal joints for lathes and milling machines in a small shop in Torrington CT in 1914. Throughout the years Borgeson has developed and manufactured universal joints for military, aerospace, industrial, agricultural and automotive applications. Today Borgeson still operates in the same city although in a much larger 50,000 square foot facility and has grown to include a full line of quality steering components.
Borgeson Universal Company continues to be an industry leader in the automotive aftermarket and strives to provide exceptional quality steering components at a fair price with unmatched customer service.
http://www.borgeson.com/
The previous owner could have set up an isolation switch. I set up one of these in my Arctic Fox, you can raise or lower the jacks but the coaches 12vdc system is off. I set up a 70amp breaker that will switch on or off or trip over 70 amps, I set it up in the battery compartment.
Thanks for the input guys. I just joined suite owners club tonight.
See you over there!
Mine has the Battery switch inside the compartment with the landing gear controls.
My 110 and 12 V breakers and fuses are just inside the entry door to the right inside the lowest door.
On my 2004 MS 36RE3, the battery disconnect switch is inside the outside door with the jack/leveling switches. It must be pulled out for the batteries to be on. The batteries won't charge unless this switch is turned to the "on" position; otherwise, the batteries are isolated.
The 120 VAC circuit breakers and 12 VDC fuses are just inside the RV below the entry closet behind the louvered door that also serves as the return air grille for the furnace.
Rusty
Pull switch on
Rusty
I did not read anywhere about that. Thanks.
