Engine/Transmission (1998.5 - 2002) Bosch 300 injectors
2nd Gen Non-Engine/Transmission How to break the bead on a tire?
2nd Gen Non-Engine/Transmission Play in steering wheel?
Has anybody run these injectors? They are supposed to be Bosch 300 HP injectors, for the 24 Valve crowd. They are supposed to be 60 hp/100 torq. Just looking for any information or experience. Thanks.
Todd
I have them in my truck right now. They are the same thing as the Bosch 275RV injectors.
A couple threads have come up on the subject recently, but you will find one answer. They are the same as the 275's, just used in a different application
They sure do work nicely with an Edge Ez :)
I have had the 275's in my truck for 80k miles and they are great for towing my 14,000 lb. 5th. whl. That is the only add I have and it really makes a difference.
They are simple to change.
Thanks.........
I figured it was too good to be true at that price. An EZ and injectors is the level I am headed for, just not sure what size injectors. I like the price of the 275's, but think I might like the power of some 2's or 3's. Just not sure if the pocket book and transmission can handle it.
Todd
Todd,
I ran just an EZ for a couple of years with no problems at all. I had purchased some 275's at the same time as the EZ, but did not install them. When I was ready to do the DTT transmission mods, I installed the 275 injectors and a larger turbo, also a Volant fresh air intake system. The stock transmission ( 47re ) started showing signs of problems within 60 days. With NO towing at all. I do not think the transmission would live with even larger injectors.
Foy
