Bosch fuel system
'03 Ecm
+ 141 lbs for HO?
I was doing some reading over at DieselPage.com and noticed that the Dmax is having problems with injectors and injector pumps. I know Bosch makes their fuel system for them and the Gen3 and I'm just curious as to how the 2 compare. Could the Gen3 face the same problems?
Justin,
A similar guestion was asked at one of the seminars at National Rally in Columbus. The Bosch rep said the fuel systems are similar; however, the Cummins system is built to Cummins specifications and Cummins uses their own electronics where as GM uses the Bosch electronics.
Bill
As many of you may have heard,the Duramax is having problems with fuel dilution of the oil. I understand that this is being caused by the injectors,and the dealers are changing all 8 injectors. I was told that this has caused a severe shortage of injectors in the supply chain. It is reported that the shortage has caused a shut down of engine production. Hopefully the Cummins injectors will not have the same problem.
