Well, I went from a DD True Torque Power Module to an Edge Comp box. I won't make any assumptions about what you already know about the Edge Comp and the DD Ultimate Module, so I'll spell it all out.
The DD TTPM is really an Edge EZ that was slightly reprogrammed to better match the fueling characteristics of DD's injectors.
The DD Ultimate Module is also an Edge Comp in disguise, also slightly reprogrammed and optimized for the DD injectors.
Since I went from the TTPM to the Edge, I can only make limited observations. I have the DD Stage 3's as you can see in my sig below.
It was my impression that with the TTPM my truck sounded a little smoother when running, and it sounds just barely a little rougher with the Edge box with their programming. Rough may not be the best word... . rather meaner I guess... . The TTPM sounded more like a purrrrrrr than a mean growl. But they are both excellent boxes. So, if you have DD injectors, it may be worth going with their version - the Ultimate Fueling Module. Otherwise, maybe the Edge brand Comp box.
Tom
