[how in the world could fuel leak out between the hold down nut/cyl head? Would have to originate from the injector body/nozzle retaining nut. ] Ok well I havent driven this truck for a long time, maybe only once since november. I think maybe the fuel/mixture of ? was leaking between the holddown nut and the inj body. - Past the o-ring. Which, when I loosened the holddown nuts, I dont believe they were torqued properly. Which is why two or three were leaking-maybe.
Oil covered injectors? --> Come on I know alot of folks have removed injectors before and no one has found any covered in oil? On my 89, one injector had oil on it, the rest were dry to the bone and rusty. Maybe this is a tell of the early non-ic head cracking.
What I'd like to do know is find out how much it will cost to have my inj's cleaned, maybe recalibrated -such a thing?, then reinstall, put everything back together, try the suggestion of retorqueing head bolts-on both trucks. This truck never showed any symptoms of HG failure, no oil in h20, no overheating, no increase or decrease of oil level. ?? Never seen any milky oil. No loss of h20. hm,mm... Once the truck is back on the road, still needs a starter rebuilt. I will get an oil sample done.
Is there such a thing as oil dye to find leaks? Thanks again to all I appreciate the help. Bill
