... its not a good idea to prefill your oil filter through the center hole, supposed to prefill from the outer holes as the filter filters towards the center lol probably doesnt really matter, i recently went to an oil school and the instructor would'nt stop talking about that... :-laf
If the oil fills through the center and comes up along the outside, explain how this is bad?
oil is filtered from the outside smaller holes and then goes into the center hole, sorry if i confused you![]()
And this is problem, filling a new filter with fresh oil, how??
Chances of introduction of FOD into the engine increases dramtically when prefilling oil filters. A little piece of the foil seal into the piston coolers and its bye-bye piston.
Overly dramatic to hammer that point, but, the instructors gotta have something to hold up for an example. :-laf
If you fill from the center hole the debris will be on the wrong side of the filter media...
I've pre*filled my last 4 CTD's since December 1997 with no ill effects..... :-laf
So... ... . in your opinion, what's the "lesser" of two evils :
a) Pre-filling the oil filter with a possible chance of foil getting inside, or
b) Starting an engine with no oil in the new filter, waiting for it to build pressure ?
Greg
I imagine, without any supporting data, that starting it dry would be worse than spending extra careful effort to prefill through the center hole.
