Brake adjustment
Wheel seals again
Power fluctuations
What’s your procedure for adjusting the rear drum brakes ? Manual shows two different tools . I normally run them down tight then back em off till there is still some resistance.
Sounds like the bearings are a touch tight...but unless you have a non-contact thermometer to see for sure...
I set them up with a little bit of end Play so they shouldn’t be . Probably doesn’t help it’s hot outside as well and the oil looks to me like it’s original
I hauled 24000 gvw the other day in 90 degree temperatures up and down some windy steep hills the axle hubs were not running any hotter than they were the other day empty so I’d say they are fine
