BRAKE AND AIRBAG LIGHT ON
2005 left front headlight (Low/High beam) not lighting
Wiring Harness Woes
TGVET
Parking and airbag light on intermittently. Anyone else have the same issue? Corrected it?
Told it could be several things.
Will a DRB2 scan and find it?
Thanks all.
My 2005 does the same thing intermittenly and randomly. I am convinced that it is a bad solder joint on the dash cluster.
When my airbag light went on on my 04, it was the clockspring in the steering wheel. I did a video on replacing it. Also my steering wheel radio buttons quit working. Not sure what the relationship is to brake lights.
On mine it was the rear sensor that showed a code, finally it was a broken wire down to the pumpkin.
Read out the ABS unit with a decent scanner that has the capabilities to do so. It will tell you where to start from.
Otherwise you are hunting a ghost inside your electronics.
Ozy, did that rear ABS sensor wire also make the airbag light go on a the same time ??
