2nd Gen Non-Engine/Transmission Brake booster and power steering problems
Engine/Transmission (1994 - 1998) twins?
2nd Gen Non-Engine/Transmission Rockauto discount code
Greetings
My brake booster started leaking fluid from an area on the bottom side of the brake booster. Also my steering became rough. I added Lucus oil power steering stop leak several times. I have now lost power brakes and steering for good.
I'm planning to replace the pump and brake booster. What does the brake booster do??? Also, can the booster be rebuilt with new seals. Since I will have the parts off the truck, should I go ahead and replace anything else???
Kindest Regards
David
truck is 99 dodge cummins 2500 2wd with 240000 miles.
