2nd Gen Non-Engine/Transmission Brake Booster Replacement
I need to change out the hydraulic brake booster, it is starting to leak worse. Anyone changed it out and took pictures. When taking off the M-Cyl. do you have to take the whole bracket assembly off to get the booster off. Anything to be careful of. The unit is available at NAPA $210 .
Pretty sure brake guru Sam Peterson sells a rebuild kit for the hydo-boost for much cheaper, give him a call he'll walk you though it also 360/357-4958
