I've got a rattle in the right front brake caliper area on my 98. 5 2500HD 4x4, I can't seem to figure out... On a rough gravel road it rattles and if I touch the brakes it stops making racket immediately... let off the brakes and it starts again. I've replaced the pads recently and tonight I replaced the caliper hardware. . rubber/plastic bushings and new bolts and slide tubes... It didn't fix the rattle. What else could it be that makes noise like that and quits the second you touch the brakes???? I did put the truck in 4x4 and jacked it up and worked the wheel back and forth to see if there is any slop in the u joint... None !... Also, put a big pry bar between the tire and the concrete floor and worked it to see if there was any movement in the ball joints... again. . None !... This is getting annoying! Any ideas anyone?
