Brake calipers
Time to replace steering box on my 06 4x4. Need information
Opinion please Lift pump
I accidentally ordered and installed the passenger side rear caliper on my truck instead of the driver side rear caliper. Will this cause any issues, or should I order the correct driver side caliper and install that one also?
Unless it is drilled and tapped on both ends the bleeder will be on the bottom and you won't be able to get all the air out. bg
