Brake Controller which one?
need opinions..bd or pacbrake
engine/exhaust brake
BarryG
Started researching brake controllers then realized I don't know squat about them. So I will ask the masters. What should I look for in one? Do they interfere with the ABS. Any info would be greatly appreciated. Brands, prices, best place to get one, benefits between different types. Are there any that I should stay away from? Trailer will probably weigh less than 6000lbs. Thanks in advance for the replies.
2001. 5 2500, 4X4, QC, LB, Dark Garnet Red, Auto, 3:54's, Tow, Amsoil dual bypass w/billet adapter, Amsoiled, Smittybuilt side bars, Mag-Hytec Trans pan & Diff cover, Line-X bedliner, Triple SPA's in the A pillar
I've researched the web, owned a few, I like Tekonsha controllers. Reese makes a good one too. When it comes to stoppin' my babies, I go for top of the line. Check out this thread:
https://www.turbodieselregister.com/ubb//Forum20/HTML/000265.html
and Tekonsha's web site: http://www.tekonsha.com/Tekonsha/DOCS/tekcat/tekcat.html
Good luck,
Pat
2001. 8 White Sport RAM 2500HD QC SLT 4X4 LB 3. 54 LSD Cummins Auto
My Ram Page
1999 21' Terry Lite Towable 5400# GVW
1990 Kawasaki KLR 250 Enduro
I have used Tekonsha Sentinals, And Reese electronic controllers. I do not care for the Reese although many others do(too much delay before the trailer brakes kick in). The Tekonsha is a good unit for the money, but will only work off of the inertial slowing of the truck (it is activated by a pendulum). Some have had pendulum units apply the trailer brakes when trying to back up an incline. A minor inconvienience that can be dealt with. Having used these types, when it came time to set up I went with the Jordan's Research Ultima 2020. This unit attaches to the brake pedal arm, and is activated by how far you push the brake pedal. It will appply your trailer brakes even if the tow vehicles hydralic system fails(something that I hope never happens). It cost almost twice what you can find the other units for, but for me it was worth it. You can check them out here--
http://www.fortunecity.com/marina/finisterre/1228/jorjan/index.htm
Sorry, it did not come up as a hyperlink when I moved it.
As noted in my sig, I use the Jordan unit. IMO, there isn't a better unit on the market. While a little more difficult to install because of the mechanical connetion, once you use it you'll know it's the one to have.
I had a great visit with Jordan at his facilities Fla. last week while on vacation. Jordan will most likely answer the phone if you call.
If you'd like more details, drop me a line.
<font color=#990000>~<font color=#990000> '99 2500 SLT <font color=#990000> ~ QC ~ 4X4 ~ LB ~ Auto ~ 4:10 LSD ~
<font color=#000000>*<font color=#990000> BD E-brake<font color=#000000>*<font color=#990000> BD Autolock<font color=#00000>*<font color=#990000> Gear Vendor OD<font color=#000000>*<font color=#990000> Bullhide spray-in Line <font color=#000000>*
<font color=#000000>*<font color=#990000> 2k Komfort 5'er - 9,700 lbs <font color=#000000> *<font color=#990000> Jordan Research 2020 T-brake <font color=#000000>*<font color=#990000> Garmin III+ & Laptop software <font color=#000000>*
<font size=-2>... Keep on Rammin'! You'll love the way it feels!! #ad
... <font size=-1>
[This message has been edited by Rattlin (edited 04-30-2001). ]
I have the Jordan also. It seems to work quite well once you get the linkage set up correctly. I also like the digital amp meter on the front. It helps alot with the setup.
Ken Lenger
2001. 5 2500 QC 4X4 SWB SLT, ETC/DDX 5 Speed, 3. 54 (no LSD), camper group, trailer folding mirrors, RBR CD/Radio, LT265/75R16E AT OWL tires, trailer tow group, Patroit Blue / Agate, Westin CPS Step Bars, Jordan Utlima Brake Controller, Weather_Guard 664 tool box
Trailite 21' Travel Trailer, ~4000 lbs loaded.
(Edited orginal comment because I can't read. #ad
Darrick, I'm surprised that the inertia unit needs less tweeking than the 2020.
If it needed a lot of tweeking, then something was wrong. I have over 15K miles on mine and no constant adjustment has been required while in use.
I found Jordan to be quite responsive to inquires and in support of his product
... <font size=-1>
[This message has been edited by Rattlin (edited 05-03-2001). ]
