Just to be the fly in the ointment here, I will offer my opinion on the subject. I have had my Jordan Research Ultima 2020 trailer brake controller installed for 1. 5 years now and love it! It not only functions better than the rest (due to its proportioning cable assembly that PRECISELY MIRRORS the brake pedal movement... no delayed reaction from a pendulum or electronic proportioning that does NOT mirror your stopping requirement), but is more aesthetically pleasing than the rest as well. In addition, the Ultima 2020 is extremely well made, using a black anodized aluminum case (instead of plastic), and does not require a mounting bracket; instead, the mounting screws pass directly through the aluminum case allowing for a lower profile, cleaner looking mount. A tow vehicle to trailer continuity LED is provided as well as an LED ammeter readout. A gain adjustment as well as a manual brake button are also provided. The Ultima 2020 can be purchased for $150. (1998 price) directly from Jordan Research.
I just thought I would add another contender to the topic.
Jordan Research can be reached at:
1-800-533-0306 (M-F 8:00 AM to 4:30 PM EST)
Their address is:
6244 Clark Center Ave.
Suite #4
Sarasota, FL 34238-2752
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X spray in liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, Air Bulldog induction hood (with NACA ducts), plus many other trick modifications
[This message has been edited by John (edited 07-12-2000). ]
