budctdca said:did you bleed the system when you changed the master cylinder? you also have to bench bleed the m/c. it sounds to me like you have some air in the system. im not sure how the system is set up but a vacuum leak might cause the same thing and the vauum pump on the dodges are known to fail. just my . 02 worth
Suprmn said:If you replaced your master cylinder with a rebuilt unit it is possible that it is bad. I have had that problem with rebuilt master cylinders in the past.
