In regards to my original post's questions about towing a toyhauler within the gvwr of both truck (3500 DRW - 12,200lbs gvwr-likely weight of 11. 5k including pin) and trailer (18,000lbs gvw -likely weight of 18k), but over the gcwr of 23k lbs: a couple of posters have said that a brake failure on the trailer would be catastrophic, and that it could be a likely thing to plan for... .
First of all, can anyone document first-hand/personal knowledge (please no "I had a buddy that said he heard . . . ") circumstances of the 7 pin connector failing or falling out? Can anyone document first-hand/personal knowledge of wiring burnout/fuse blowing, etc, with a fairly recent model of 5th wheel trailer causing total brake failure? Are brake failures towing 5th wheel RVs common?
Anybody have knowledge of how quickly an exhaust brake (used in lower gears/higher rpms) assisting the disc brakes on an '06 DRW 1 ton would stop a large toyhauler such as above?
In looking at MDTs recently, I noticed they all appear to have 16" drum brakes. The Dodge 3500s have massive (thick) 14" discs. Anyone have any actual knowledge of how much more effective a 16' drum/19. 5-22" tire is going to be compared with the 14" disc/17" tire? I might assume in a short distance panic stop, the 16" drum might work better, but on a grade, wouldn't the obvious fade resistance superiority of a 14" disc close the braking "gap"?
In talking to this MDT salesman (yeah I know, he was trying to sell a truck), he stated that none of the 5th wheel RV trailer were designed with enough braking capacity to stop themselves and that the tow vehicle had to do some, if not most, of the stopping. I thought that each vehicle (tow and towed) was supposed to have at minimum, sufficient stopping ability to stop itself. I thought that the addition of a vehicle behind another vehicle was not supposed to put an additional (or certainly undue) braking load on the front tow vehicle. Anyone know what is really true?
