2nd Gen Non-Engine/Transmission brake fluid
how mush brake fluid do i need to bleed all of it out and then put fluid back in. i was thinking of putting in castrol gt lma dot-4 what do you think
Bleed it out and keep refilling with the new fluid until the color is 'right'. Avoid introducing air into the system if you can. Use only new, sealed bottles; brake fluid, like alcohol, loves to absorb water.
