Because of an electrical problem with the brake lights, I have to disconnect the battery ground wires.
When the ground wires are re connected, the brake lights come on steady or the will flash. I have checked the brake controller and it is working correctly. All other lights and accessories are working correctly. The Stop Light switch on the brake pedal is not sticking. Almost forgot, there sounds like circuit breaker clicking--the sound comming from behind the A/C Heater controls or center of dash.
With the trailer attached and batteries disconnected the truck is either getting 12 V or a ground from the trailer.
Without the trailer, disconnecting the driver side ground first, the under hood light goes dim but not out. disconnecting the passenger side battery first, there is no change in the under hood lights brightness.
Anyone else have this situation or know where to start for correcting the problem???
