My 01 2500 4x4 has no brake lights. I bought the vehicle used about 5 mo ago, it had an electronic trailer brake unit installed by the previos owner. I first noticed no br lights 1 month ago when hooking up a trailer, did my light check, and found out I didn't have brake lights. I also noted that I didn't have brake lights on my truck as well. I assume this problem is not due to bulbs, since both the truck and trailer don't work. I have not been able to correctly identify which fuse is for the brake lights, but have inspected most of the smaller fuses and found no apparent problems there. I even replaced the smaller fuses located inside the cab with known good ones, still no lights. I replaced the brake switch behind the foot pedal, no luck here. Yesterday I removed the electronic trailer brake sending unit, inspected it. It appears to be electrified, since lights come on and off. The wiring to the electronic brake unit appears professional. Why can't I see the light?
