brake line lock good idea?
Bilstein Shocks for 3500, 2 Wheel Drive
WHOOPS! I did it! Locked out!
Have an 03 with standard trans, has anyone heard of installing a line lock and using it instead of setting the emergency brake each time i park? Seems it would be easier to flip a switch instead of pushing the emergency brake petal down.
i did this on my jeep. the only bad thing is when you turn on the switch is needs power all the time, which would eventually drain your battery. you could find a push/pull line lock(without power) and run brake lines through the cab to the valve also. good luck.
